Where I can change drawen curve for a curve with calligraphic stroke. No draw new curve with calligraphic, but how can I add to existing curve calligraphic stroke.
Excuse my simple questions, I use Inkscape only 3-4 days.
how add to curve calligraphic stroke
Re: how add to curve calligraphic stroke
To add to an object using
you can select the object and hold shift as you draw. Sorry if that's not what you're asking.
you can select the object and hold shift as you draw. Sorry if that's not what you're asking.Re: how add to curve calligraphic stroke
I decide to add calligraphic stroke later , when I have drow curve yet. Is it possible to change stroke to calligraphic stroke post facto?
Simarilius
The nearest you can do is add a path along path Effect to it to stretch a curve down it.
Its easier to do in the development as you can apply it as an LPE.
Thanks, Simarilius
