OK, I want to try to make a text file to be imported into a 3d printing application. But to do that I need to create the text. I want the text to look like the attached Chevrolet script. Note that the font is OK, but how to raise up the middle like this is challenging.
How can I do that? I have tried all the filters and nothing works like I want it. So, what else is available?
E
How to make this text
- nt5710_big.jpg (3.78 KiB) Viewed 856 times
Re: How to make this text
Is your 3D printer able to print in color? Or what would you like to achieve? What do you mean by 'raise up the middle'?
(Just in case: the 3D in the drawing is only *simulated* by adding shading / filters / gradients - you'll need to do the 'raising' in the 3D application. SVG is 2D only)
OP might want a centerline-based style gradient, to height-map in another program.
e.g. capital H, in a block font:
Ah, that makes more sense, thanks, @tylerdurden!
