I'm using Inkscape v 0.46 on Windows XP.
Currently, when I gradient fill an object and either move it or resize it, the gradient nodes do not move with the object.
Here is my project:
http://s293.photobucket.com/albums/mm54 ... nshot1.png
I need to resize it for a print job so I change the document properties to the print specs:
http://s293.photobucket.com/albums/mm54 ... nshot2.png
When I resize the objects (either grouped together or not, it doesn't make a difference) the gradient handles/nodes stay in the same place and don't move with the object.
http://s293.photobucket.com/albums/mm54 ... nshot3.png
This is a minor problem because I can always grab the gradient handles and move them manually, but I'd rather not have to take the time. Suggestions?
[solved] Problems with gradient NOT moving with object
Simarilius
Re: Problems with gradient NOT moving with object
theres a little icon on the right end of the selection toolbar that toggles gradients moving with their objects or not.
Thanks...
Here's a link to more explanation...
http://ryanler.wordpress.com/2007/08/17 ... an-object/
RTFM...
RTFM...
