Hello i am new in inkscape and i have pair of questions
1.- is dead this project? Because there is still in 0.48.2....
2.- i want be UI designer / web designer concept , Do u recommend me use inkscape for develope concept for web design?
New inkscape
Re: New inkscape
Welcome to InkscapeForum!
1. Info about 0.48.3.1: viewtopic.php?f=22&t=12627 (long discussion, confusing, but all the facts (from ~suv) are correct!).
2. Do you mean you want to use Inkscape to create websites? Yes, it can be used for that. Be sure to look through the extensions found here, because some of the features that you might need to develop websites are not (yet anyway) built into Inkscape http://wiki.inkscape.org/wiki/index.php ... Repository.
Re: New inkscape
brynn wrote:Welcome to InkscapeForum!
Thanks for your response
Thanks and sorry for my english. I speai spanish and not much english but i am learning it
Re: New inkscape
Someone else will have to discuss whether GIMP or Inkscape would be better for you, because I'm not familiar with the particulars of web design.
What I meant about "not built in" is that when you install Inkscape, there are a lot of extensions readily available, right there in the Extensions menu. But at the link I gave you are more extensions, which don't necessarily appear in the Extensions menu. Some extensions which might be used in web design are found at the link (which is a the Extensions Repository) which are not installed.
