Why can I not get Clip to work consistently?!!
micro, when you have a chance, can you have a look at this file? As always, no rush
http://www.petaimg.com/uploads/1224713345.svg
As per our last communication on this issue (viewtopic.php?f=29&t=1656), in which we discovered a bug, clipping is supposed to work when using a clipping path which has a fill/stroke. As I mentioned at the end of that topic, I had not been able to get clipping to work, except by removing the fill/stroke of the clipping path. And here is the perfect example.
I last saved this file (b4 uploading) with layer Layer 1 not visible, and zoomed to 800%. So when you open it, you should see a bright green circle with a black stroke in Layer 3. That is my clipping path. Below it is a group of 2 objects, also in Layer 3. You can see the blur that needs to be clipped away, peeking around the edges of the green circle. And this is right before I do Clip > Set.
When you select the group and the green clipping path, and set the clip, you can see that the clip worked, because the blur disappears from around the edges. But the green circle with black stroke is still there!. If you remove the fill and stroke from the clipping path, rubberband select and clip, then you have a normal appearing clipped group of 2 objects.
So what's the problem here? Has the clipping path actually moved again? You may remember that I'm using v 0.46, and don't have the ability to locate it. If it has in fact moved, we have very different circumstances from the file used to report the bug.
A. I'm not trying clip across several layers, as before; and
B. I'm not trying to clip several objects, just one group.
I might also mention that this was the same canvas where I'm having trouble making single dots using Ctrl + click, where the dots show up far away from where I tried to put them (viewtopic.php?f=5&t=1764). (I cleaned up the canvas to give you a relatively uncluttered file, so the dots aren't there, but you can probably try to create dots, and see where they show up.)
Also, I was going to PM you to look at this topic again - viewtopic.php?f=5&t=1695. It may or may not be related to this. In this topic, apparently my use of "Fit page to selection" (on the Page tab of the Doc Prop dialog) caused transformation data in the XML Editor to be assigned to all the layers, even though the transform was done on one object in one layer. This caused my tiled clones to be sort of sprayed all around the canvas, instead of where they should be. loonquawl and I aren't sure if this is a bug or not. But I've used one transformation or another on all 3 of these images, as well as "Fit page...". And if using the "Fit page..." is causing some weirdness with transformation data, I wonder if that might explain ALL these problems?
And once again, thank you very much for your help. Also no rush, I know you can't always access petaIMG-hosted files. Whenever you can open it is fine with me
