Hi all,
I use Inkscape in conjunction with Graphtecprint to print to a Quickutz Silhouette-1 cutter.
It's been working fine up until I included a new graphic. I imported the Graphics, traced the Bitmap, placed the tracing where I wanted it and thought great, copy and paste a few more.
Everything was displayed OK, but when I came to print to a ps file and put that file through Graphtecprint all I get is 'Nothing to Print'
When I edit the 'ps' file I can see that Inkscape has saved it as an 'Image' and not vector commands so Graphtecprint can't use it.
Any ideas as to how I can convert the lines which I thought were paths to work correctly.
Thanks in advance.
Only Image Tag in Postscript File no Vector information
Re: Only Image Tag in Postscript File no Vector information
Sorted it - the Opacity was set to 98% - I reset it to 100% and it worked. Created a Postscript file that then when trough Graphtecprint to the cutter.
Perfect.
Perfect.
Ah, well a bit belated, but
Welcome to InkscapeForum!
I'm glad you figured it out
Also, I'll move this to Cutter/Plotter forum, in case others might benefit.
