If I start with an image which contains lots of stepped gradients, is there a way of changing the overall colour of the object without editing each and every gradient? Here's an example:
Can I easily convert this image:
...into this one:
Thanks.
Great idea! I've tried it and it works, although you do need some basic understanding about those blending modes to be able to predict the result.microUgly wrote:If you're prepared to use a development version of 0.46 you could also draw a shape over the image and change its blend mode to influence the colour of the image below... hope that makes sense.
