Noscape on win7 :Incompatible with win7???
I keep getting an error message when i try to open inkscape.The application was unable to start correctly (0xc0000005).Click OK to close the application.this happens with all the versions of Noscape err i mean inkscape.
Re: Noscape on win7 :Incompatible with win7???
Inkscape works on Windows 7. Check the forum FAQ for things to try.
Inkscape works fine with Win 7. Try this link to see if it helps with the problem. could be your Win 7 that's buggy.
http://windows-exe-errors.com/fix-windo ... xc0000005/
Also ghostscript may help. I have it because Gimp.
http://code.google.com/p/ghostscript/downloads/list
Good luck.
Good luck.
