I have dozens of older files created in the old version of Inkscape. With the latest version (0.92.), I am unable to set the correct dimensions with one always changing to "1" and the DPI changing to 100000. At first, I thought it was old files, but I just checked again, and it's a brand new file and a single filled rectangle.
I cannot export it correctly, it defaults to 16 x 16 at 100000 dpi. Going to go back to the old version - I liked it better anyway.
Broken export routine
Re: Broken export routine
If you'd like to provide us with more details, we might be able to help you solve the problem. I can't imagine what it is that's' changing to "1". Do you mean that when you change the DPI in the Export PNG dialog, it doesn't stay there, and it's changing to 100000? If that's what's happening, there certainly must either be some explanation, or it's a bug. But we can't discover anything, either way, without more details.
When you open an old file with 0.92 or 0.92.1, do you see the Old Inkscape File Detected dialog, which offers you 2 different ways to automatically scale either the file or the objects in it?
If you could share the specific file with us, we could help you figure out what the problem is. You can attach it to....well I don't think you can make attachments in this board. But you could upload it anywhere you choose, and give us the link to it.
trogladyte
Just discovered the problem - pilot error! DOH. Just never noticed before that there's 4 tabs across the top of the Export Pane. Mine obviously always defaulted to "Selection". I just looked and it was on "Custom" although I would have expected that to work differently than it did. Switched back to selection and all is good.
Apologies!
Apologies!
Attachments are permitted. (You can also link if you like.)
- Im_An_Attachment.svg
- (2.89 KiB) Downloaded 380 times
trogladyte
Weird. I already replied to this, but the post is nowhere to be seen. I found it was actually my fault. I had the "Custom" tab selected, not "Selection". Changed it and all back to normal. Though I have no idea why, if "Custom" is selected, the program automatically changed parameters.
tylerdurden wrote:I don't think you can make attachments in this board.
Aarrgh - I can never remember which boards allow attachments!
