http://www.inkscapeforum.com/viewtopic.php?p=44911#p44911
and also installing ImageMagick).
I am able to trace and save to a svg file with a command like:
color_trace_multi.exe -i a.png --output a.svg -c 4Works pretty well... a few anomalies which I'll save for another thread.
Question... With interactive Inkscape, you can save the a bitmap_traced image to many different file formats other than SVG. In particular, I want to output to PDF. I checked out the command line arguments for color_trace_multi.exe and don't see any way to specify the output file type. Is there a way to control that?
