Is there a way to open a closed curve?
I'm trying to export a curve as a path for a cnc machine to follow but a closed curve becomes two parallel paths with closed ends in the dxf file. An open bezier exports correctly.
Opening a closed bezier curve
Re: Opening a closed bezier curve
Using
, select a node and click the split node button the tools control bar (above the canvas) -- http://www.microugly.com/inkscape-quick ... break-node
