I imported a PNG image into Inkscape 0.46. I wanted to fade a portion of it to transparent to reveal a layer underneath.
Although Inkscape shows the Fill and Stroke dialog, and lets me specify and edit a gradient on the object, it doesn't seem to work.
Are gradients on imported images not supported, even though the interface gives every indication that it is supported?
Or am I missing something simple?
Thanks,
-Ken
Gradient on Imported PNG?
- EarlyBlake
Re: Gradient on Imported PNG?
You can change the transparency of part of a png by masking it. Mask is under the object menu. A png is a kind of bit map not a vector so inkscape looks at it as an object, so fill and stroke don't work on it.
Screen shot: http://www.inkscape.org/screenshots/gal ... ffield.png
Brief tutorial: http://aqeeliz.com/2007/03/12/inkscape- ... eflection/
Thanks, EarlyBlake. Very useful information.
To other readers: be sure to read the last comment on the Reflection tutorial -- it gives critical missing details that will help ensure you get the results shown.
