I don't know which would be easier on the system: running 2, 3 or more copies of Inkscape in order to work cross-document, or having each document open within one instance of Inkscape.
Lazur URH wrote:My only problem with the idea is that some heavy vectors can crash inkscape.
When you work on several files at the same time
-for an example, copying an important part out of a large messy svg-,
if all were only on a new tab, a freeze could crash the others as well.
In my opinion if inkscape would perform fluently, multiple tabs could make working more organised, which would be good.
Pilosopong Tasyo wrote:BobSongs wrote:I don't know which would be easier on the system: running 2, 3 or more copies of Inkscape in order to work cross-document, or having each document open within one instance of Inkscape.
I checked with System Monitor and it looks like only one instance of Inkscape is running across multiple documents. Additional RAM gets allocated on demand (creating objects, opening new/existing drawings, etc.). So based on this observation, I don't think multiple-tabs versus multiple-windows would make a huge difference on system resources. YMMV, of course.
That said, tabs would be nice. It's a convenience, and it will surely lessen window clutter when doing edits on multiple drawings.
