my vistablet just quite working with inkscape.
i can move the mouse around, but i cant paint, draw, select, etc..
the tablet works fine with other software, and on the desktop.
aaagghhh!
it was all working great, then.....
thanks
brian in atlanta
inkscape with a vistablet
Re: inkscape with a vistablet
Well, if it was working normally, then stopped suddenly, I would suggest reinstalling Inkscape, as well as tablet (if it has software, I'm not familiar with tablets). If that doesn't help, here is a list of the many already existing topics about using tablets with Inkscape. You should be able to find the answer somewhere in these topics.
viewtopic.php?f=29&t=4107
viewtopic.php?f=29&t=3054
viewtopic.php?f=5&t=4164
viewtopic.php?f=5&t=5448
viewtopic.php?f=5&t=4055
viewtopic.php?f=21&t=1091
viewtopic.php?f=5&t=471
viewtopic.php?f=29&t=3870
viewtopic.php?f=22&t=1505
viewtopic.php?f=5&t=1771
bernsaxman
I have the same problem with my Vistablet.
AFAIU this is unlikely to help with regard to possible issues on Inkscape's side: the settings for extended input devices in Inkscape are stored in the preferences file (%APPDATA%\Inkscape\preferences.xml) and are not reset when reinstalling Inkscape. If the tablet worked and suddenly stopped, possibly the settings had been changed?brynn wrote:Well, if it was working normally, then stopped suddenly, I would suggest reinstalling Inkscape
One could try to either
- reset Inkscape's preferences (quit Inkscape, rename or (re-)move the preferences file), relaunch Inkscape and reconfigure the tablet (menu 'File > Input Devices…')
- check the 'Input Device' settings directly without resetting the preferences to default values
- manually edit the preferences file as described by druban and confirmed by other users in the topic "Re: Tablet not working in recent dev builds"
