I am new using INKSCAPE and I found that when I use text and then convert to vector some lines on fonts do not show
i am trying to add jpg file to show what I get after vector but does not accept
thanks
Problems with some FONT styles
Re: Problems with some FONT styles
Don't use flowed text, or, if you do, remember to convert to TEXT before converting to PATH
NConstantinou
Sorry what do you mean convert to text.
when I type a text and finish I use TEXT,combine and then object to path. after that I save file in SVG format.
is this wrong
is this wrong
So, this is what I see:
What is missing?
Flowed text and normal text convert to path the same way, at least to my knowledge. I assume this must be something else, but don't know what yet.
What is missing?
