I've been trying to use the Gradient to Path technique, from this tutorial, which jude mentioned in a different topic thread (viewtopic.php?f=6&t=1175). I'm having some difficulty with it, though, and am unsure how to get help with it. If I spoke German, of course I would join the German Inkscape Forum and post a topic asking for help, there. But alas, no German
So I'm gonna go ahead and post my questions and screen shot here, and hope some of the bright Inkscape users here, can help me. If not though, can you suggest how I might get help with this?
Here's a link to a screen shot (it's a bit large to insert into this message). So you can see that where the path curves, the markers overlap. And since they have an alpha value, the overlap results in darker and lighter areas, instead of the smooth appearance shown in the tutorial. Not only are the overlapped areas a problem, but on the other side of the path, the markers are spaced farther apart, resulting in gaps in the gradient/path.
What have I done wrong? Do I need more nodes, less nodes? Should the marker be wider, thinner? I thought I understood from the tutorial that transparency can be used, but maybe I misunderstood -- maybe the marker has to be opaque? Or maybe I need to try a different shape for the marker? I tried some of the various marker shapes that are included, (circles, dots, arrows, etc.) but they would not take on the gradient. I'm thinking I could convert a letter 'S' to path, add the gradient, and use it for the marker. Maybe the 'S' shape would help with the gaps....but they'd make the overlaps worse.
One problem that I've noted, is that when I used Effects > Modify Path > Add Nodes, it distorted the path. Originally the path followed the edge of the dark brown object. I know how to fix that, though.
It's the overlaps/gaps where the path curves, that's got me stumped. Any suggestions?
I appreciate anything you all can offer!
