Right now I am making a Dutch Wordpress blog on Inkscape. I found out, that as a rule, it is not possible to upload svg files to wordpress, because of 'security reasons'.
So I wanted to make some svg files downloadable via Dropbox, but there you need an account before you can really download files I shared. But I don't want to force readers to make a dropbox account.
I do know about openclipart, but that is not always the right place for 'just a file'.
Does anybody know a better alternative for this?
I would be very happy to find a good alternative.
Inkscape SVG & wordpress
Inkscape 0.91 and 0.92.4. Writing a course about this beautiful program.
Re: Inkscape SVG & wordpress
Hello...
I think that in dropbox exists a "Public" folder which you can share the link with everyone. But I may be wrong...
In deviantart, perhaps. But keep the secret
If you have problems:
2.- Please check here:
Sharing a link does not usually require a login, invitations usually do.
if you want to hotlink, look at the URL here
note the "dl"
https://dl.dropboxusercontent.com/s/ew8zqjc8dy9owj7/Cut-Pie.svgnote the "dl"
Hello tylerdurden & hulf2012,
Thank you for answering so quickly. I found that my shared files are not downloadable, if they do not show correctly. For example, a shared ordinary jpg is displayed correctly and then you can download it from dropbox, without a login.
I have made an Inkscape SVG file, with layers, which does not display immediately, only after being logged in.
One shared file:
https://www.dropbox.com/s/nxtxetujq3rsg ... rlands.svg
It does work, if I make it a complete shared directory, which you can then download as a zip file. Strange, isn't it? So that is a bit annoying.
A complete directory:
https://www.dropbox.com/sh/fyrq9102r496 ... zzUYLq11na
It is an edited version of vwanweb's beautiful file on openclipart, by the way.
One shared file:
Hello McRoth,
may I get it a bit more clear:
Right click file/share link/copy url/paste url/delete the www part from the url and replace it with dl
See:
https://dl.dropboxusercontent.com/s/nxtxetujq3rsgtk/Inkscape_toetsenbord%20met%20sneltoetsen%20in%20het%20Nederlands.svg
or
svg here
or
See:
or
svg here
or
Thank you, now I understand the dl-bit. I will write this solution down immediately.
Thanx to all again.
Tomorrow I will try this on my blog, and if it works I will let you know.
Thanx to all again.
So, I could not wait untill tomorrow. It works fine thisway, thanks a lot!
Just saying,
It's a great hack that one of dropbox. But their administrators are aware of this?. Someday they could change their policies about SVG images.
Or am I wrong?
Or am I wrong?
Well, I still do not really understand how it works, but fortunately it does work. Very nice.
hulf2012 said
SVG is (becoming) an open standard on the internet. So it would be wise for Dropbox to make it easier to share such a file, not more difficult. But we will see.
I think it is intentional, not a hack.
Dl stands for download, and in that manner it could go even further, as openclipart can for example.
normal url:
https://openclipart.org/people/Lazur%20URH/szaka5.svg
modified url:
https://openclipart.org/download/people/Lazur%20URH/szaka5.svg
At dropbox limitation is connected to the free storage size, and maybe to the bandwidth as well.
With simple svg-s it is unlikey to exceed those.
normal url:
modified url:
