Post a quick tip
Post a quick tip
Double clicking a tool icon, opens the preferences for that tool.
Re: Post a quick tip
Diagonal guide lines can be pulled off from the ruler's corners.
With CTRL pressed down you can select an individual object in a group.
With Alt pressed you can select under an object.
You can delete all your guides at once by going to 'Extensions - Render - Guides Creator', tick 'Delete existing guides' and hit apply.
Guides can be hidden by clicking on the rulers.
You can delete all guides by Edit/Delete all guides.
To edit an instance of a symbol, un-link the symbol (similar to clones) then ungroup.
(This is not explicit in the status-bar tooltip).
To delete a guide line hold Delete and hover over the cursor the guide line.
If something doesn't work, look at the status bar at the bottom to get relevant information.
To rotate a guide line hold Shift and pull it.
Look at the
Status Bar
Status Bar
To use the dropper tool (D) choosing a stroke colour, hold Shift.
In 'Preferences -> Behaviour -> Steps', you can customise the move value for your arrow keys and rotation steps.
You can copy/paste an object's fill&stroke&filtering attributes by selecting object to be copied, pressing Ctrl+C,
selecting target object and pasting style by pressing Ctrl+Shift+V.
double clicking with the gradient tool on a gradient "line", inserts a new stop
You can use H and V keys to flip a selected objects/selected nodes.
cleversomeday
Shift-clicking a color swatch changes an object's stroke to that color.
To select a bunch of objects, use the Select Tool while holding down Shift and Alt. This draws a red line and everything the lines touches, gets selected.
dimumurray
snapping tools...use them...they're awesome!
Ctrl+Alt+V pastes objects exactly where they were copied to the clipboard.
The 'Pattern Along Path' Extension and LPE distort the pattern. Scatter doesnt.
You can enter a cloned group's parent object and paste in/draw other objects.
Many number input fields provide a list of preset values for you to choose from when you right-click on them.
Double-click on the words "Fill:" and "Stroke:" in the bottom left corner to quickly open the fill or stroke tab of the Fill&Stroke dialog.
