Hi again,
My need is to be able to see (in order to keep the value and put in another files) a rotation in ° applied to an object.
In a web application being developed, we need a 'map' very precise - not gmap, even it's quite the same principle-
Purpose is to use Inkscape to create one at a time a rectangle that represent a small area and catch its coordinates
position this rectangle to one very place on astreet map (background)
rotate it to align with pavement side
save the coordinate x, y and rotation applied in degrees- but this can be done with a few manipulations - (and save it for instance manually in Excel)
duplicate an object model, do the same again and again.
Need some suggestion
thank you
How to display permanently the rotation done to an object
Guest
Re: How to display permanently the rotation done to an object
I would say may be there's a way to parse the svg files to extract the data I need ...
By obvisouly.. I dont see whre to find the rotation value ....
Inkscape uses a transformation matrix to define the rotation. How the matrix works is over my head, but you can read about it at http://www.w3.org/TR/SVG/coords.html#Tr ... rixDefined
Note that you can define the rotation using transform="rotate(30)" (where 30 is the degrees) but Inkscape will convert that value to the matrix value.
thank you.
Not clear at all, but I'll ask to super MathMan some help
