Hope you're all having a great weekend.
Fairly new to Inkscape and need some help. I'm using Inkscape to create and export .EPS files to a plotter.
I imported a pic of a car and did the following.
Path>trace bitmap>3 colors>3 scans. This was the simplest I could get it and still keep the images form.
Removed original. Edit> select all. Object> group.
This locked the layers together, and I can somewhat cleanup the vectors individually.
Is there a way to 'weld' all 3 layers together? So that each layers nodes showed up as 1 full vector.
Or is there a better way to go about this?
