I created playing cards but only duplicate the seed! But now I should change with the duplication of clones:
could be duplicated in the transformed clones without replacing everything ?
Transformed clones in duplicate
Re: Transformed clones in duplicate
I didn't understand what you are asking. I can only guess that you made duplicates of an original, but now you want them to be clones instead of duplicates right?
I don't think there is a way to do that, but you can easily create lots of clones using the Create tiled clones option.
00Inkscape
thanks ... then I put a remake ... but there is not even a plug_in which gives the properties of the clone! even in svn ... nothing!
I understand you're having trouble, but I have no idea exactly what you're trouble is
I suspect you don't understand how to use clones, so this page should help you - http://tavmjong.free.fr/INKSCAPE/MANUAL ... lones.html
00Inkscape
but I do not know! the fact is ... you see this file:
http://www.mediafire.com/file/ovzkcqnjyn4/NewIta.tar.gz
the proposed bugzilla for Asleriot
I have practically all the seeds Duplicate but loads slow!
I was advised to clone as possible to load faster! now I have done this:
http://www.mediafire.com/file/ymywdunwwnj/NewITA.svg
where the bottom half French and I have cloned remade the image of Italian seeds is a bitmap, but if I am asked to clone the semi Italians I would not mind a plug or some way to be cloned.
Blender is the 3D program known OS that is very easy, just change the masch attached to the pivot and also changing masch does not change the position of the object (it would be handy indeed)
