So I started tinkering:
I got many ideas but don't know which direction to go. The middle with the map is mostly bothersome atm.
(please try to comments to design and not about the metal genres)
Simarilius wrote:I'd try a map without the borders, as the current one is a bit visually cluttered.
Simarilius wrote:I'd also change the size (and maybe font?) of the text in the black ring as its kinda getting lost in there at the minute.
Simarilius wrote:Nice start tho.
Simarilius wrote:I'd go solid rather than outline, and delete some of the smaller islands and so forth to clean it up...
EarlyBlake wrote:Could you get a map that is looking down on the globe from a point above the north pole that would give you a lot less negative space. Or warp and simplify the map more the ad some longitude and latitude lines. I see people do that a lot to deal with the space issue.
Cedworth wrote:Much improved over the first version. The solid black works. Maybe put a pentagram in there somewhere. Maybe as a map compass rose.
Cedworth wrote:or make the spikes behind everything into a pentagram. I think it would make it more 'metal'
David Hewitt wrote:It looks good in itself but my only comment would be that there is not much about the logo that screams out METAL!.
I would be trawling the net for some seriously stereotyped images of raging head bangers in full metal regalia. For inspiration...
What ever it is you do it should say METAL with out having to be read...
I would love to see a motif some how portraying a serious Metal head stereotype.
Something that typifies your headbanger! A Metal logo needs some serious double kick! LOL
Thats just what i would like to see... your logo looks fine otherwise.
