I have a tablet PC (HP TC4200) with Windows XP Tablet PC Edition, where I draw directly on the screen using the stylus. I haven't been able to get the pressure sensitivity to work in Inkscape (it works OK on ArtRage for example), I can draw etc. with the stylus, just no pressure sensit.
When I select the "Input devices..." menu, I get the dreaded "No extended input devices", with OK button disabled and cancel button enabled.
I have the same problem in GIMP if that is relevant.
I searched / googled / etc. and found that many users have this problem with Wacom graphic tablets (intuos, graphire, bamboo, etc) i.e. hardware that you plug into a PC, but my setup is different, I have no "separate" tablet, mine is "embedded" into the computer / screen. Also most cases seem to be related to Ubuntu, which I don't use (I'm on Win XP)
What should I try to do to make it work? I tried on several inkscape versions including 0.47 pre4
Thanks in advance!
