to create text, it will not let me capitalize any letters, neither with shift nor with caps lock. The same thing happens when I make a new layer and try to rename that layer using a capital letter.. This just started happening right now. Thank you.I cannot capitalize any text..
Hello, when I use
to create text, it will not let me capitalize any letters, neither with shift nor with caps lock. The same thing happens when I make a new layer and try to rename that layer using a capital letter.. This just started happening right now. Thank you.-
styxlawyer
Re: I cannot capitalize any text..
Which OS and what version of Inkscape are you using?
I am using Windows 7 with Inkscape 0.91.
styxlawyer
... and does the shift key work in all other applications?
Yes, both shift and caps lock works, this is only happening with inkscape.
styxlawyer
OK. As it's Windows first thing to try is restarting Inkscape. If that fails restart Windows which usually fixes these things.
Ok thank you, I tried it but it did not work, I might just reinstall inkscape.
I reinstalled Inkscape and it solved the problem, but once I start messing with the Ctrl key to write a copyright symbol, it wont let me capitalize any longer. I don't really know how to write symbols.. Any ideas?
Check the Glyphs, from Text on toolbar.
styxlawyer
future12 wrote:I reinstalled Inkscape and it solved the problem, but once I start messing with the Ctrl key to write a copyright symbol, it wont let me capitalize any longer. I don't really know how to write symbols.. Any ideas?
Doesn't Windows 7 have "Character Map"? It's on my 8.1 system.
