Why is this image so big?
And what can I do to reduce it?
- People_2.svg
- (214.71 KiB) Downloaded 325 times
Re: Why is this image so big?
The file has ~3000 lines of illustrator code inside. A unix/text editor can be used to clean out the code.
file is a bit smaller now. 83 lines.
- People_2.svg-td.svg
- (3.49 KiB) Downloaded 294 times
Or copy and paste the content into a new fresh file - page size scaled to fit content - save = 2.471 Byte:
P
P
Yes, there is Adobe Illustrator code inside the file.
You need to remove this code:
and this:
and all this this code:
And then you have cleaned the file from superfluous data.
<switch
id="switch3"
</switch>and this:
<foreignObject
requiredExtensions="http://ns.adobe.com/AdobeIllustrator/10.0/"
x="0"
y="0"
width="1"
height="1"><i:pgfRef
xlink:href="#adobe_illustrator_pgf" /></foreignObject>and all this this code:
<i:pgf
id="adobe_illustrator_pgf"><![CDATA[ (AND ALL THE LINES IN BETWEEN!!!!) ]]></i:pgf>And then you have cleaned the file from superfluous data.
