I would like to see a feature now available only with the clone tool. Suppose I select multiple objects and scale them in an "individual mode". Then the scale would not affect the whole selection, but rather all selected objects individually, just as if I were scaling the original in a clone array.
In my case I import SVG's (exported by Mathematica) which contain data points. Right now I'm not able to resize the points (in the number 300 or more) if I decide they are too big or too small.
This would be solved also if I could make a selection of objects into an array of clones, which can't be done right now.
Maybe there is an extension which does exactly that, but I havent found it. In this case I'd be happy to know
Regards,
Karol
