I'm using the Inkscape version 0.48+devel r12685.
I'm not sure where to post this issues that i'm having with the development version of inkscape. The one that it's built for windows which download link appears in the download page of Inkscape (suv, microugly?). Here are some:
- Power Stroke: The problem appears when you apply the Power Stroke Path Effect to a closed path. When the path is closed, it seems that the path effect tries to generate a stroke of infinite thickness. Maybe I'm not expresing correctly. But It's easy to see when you create a closed path and then apply the power stroke path effect.
- Measure tool: In older development versions, that new tool was working correctly, at least It seemed to me. But In this version, with some complex paths, it has a delay, or don't appear at all, when clicking and draging the mouse. Also, this is just a wish: Could it be posible to choose to "freeze" the measure widgets that appear?. I mean, to convert the dimensions to svg entities.
- The Mesh grid "secret feature":In an earlier version(Inkscape 0.48+devel r12483) some users have managed to work with this tool, but in this vesion (0.48+devel r12685) it doesn't work good. It crashes when I try to edit the nodes.
- The New "Trace Pixel Art" tool: I import a big image, let's say a 100x100 pixel picture or bigger. I trace with the tool. Some times, or the program crash or it takes an eternity to trace the image. So, what is the limit of picture for that tool?. If the image is little, it just generates a grid of squares or a mosaic -kind of image.
So far, It's what I can see.
Any feedback is welcome
