Hello,
1. "snap to nodes" is activated
2. I click on an end node of path A and snap it with the other end node of path B
3. I combine path A with path B "ctrl + K"
4. When I join the two snapped nodes, inkcape creates a tiny segment in between.
But all I want is a single node.
[solved] how to join two nodes that are snapped
Re: how to join two nodes that are snapped
After step 3, select the two nodes you wanted to join and with
and click the join node button on the tool control bar.
and click the join node button on the tool control bar.Re: how to join two nodes that are snapped
Thank you! Of cours it works.
I should have known this myself. Somehow I kept clicking the wrong button.
