Hi there,
I am a completely new user to Inscape. My main purpose is to use it with latex. I created an image but when I save as pdf, I am unable to view the output with Adobe Reader (however it is visible in the preview).
These are the details:
OS: Windows 7
Inkscape version: 0.48.5 r10040
Adobe Reader version: 10
I've attached the svg file below:
These are the sequence of operations:
File- Save as - *.pdf
These are the options I select on the popup:
http://imgur.com/3cPmOGT
For my example I don't need to select the 'PDF+LaTex option' but either way it doesn't work.
I was originally trying to export this drawing using the save as pdf option:
http://imgur.com/ORIYRUp
But when it didn't work, I went for the most basic option.
I would really appreciate any help!
I'm aware this may not be the place the post this, if not, I would appreciate advice on where to submit.
inkscape generated image not visible in adobe reader 10
inksc_nuser
- drawing.svg
- svg file
- (2.01 KiB) Downloaded 191 times
Re: inkscape generated image not visible in adobe reader 10
I'd try using the "export area is page"... seems to work here.
Seems to work w/ export is drawing too...
FWIW, Adobe reader 8
inksc_nuser
Thanks for your help.
I think I've found the source of the problem, though I don't understand at all why it's happening.
It's unrelated to Inkscape.
It seems that Adobe Reader (AR) doesn't like having more than 1 file open which contains Inkscape generated graphics. I need to completely close AR application and restart it if I want to view another pdf which contains Inkscape generated graphics. I don't know if this just applies to AR 10 or all (or if the problem is with my installation).
Thanks again,
Thanks again,
