I should probably sign up to the gimp forums for this question, but maybe someone knows the answer here.
Because of a small bug with Inkscape I have to rotate images in the gimp first.
But when I am rotating is there a way to hide the un-rotated image? I can only see how to hide the rotated image.
Seeing the previous image underneath makes it hard to see the edges clearly.
Gimp Rotation tool - can you show rotated image only?
Vectorator
Re: Gimp Rotation tool - can you show rotated image only?
I set the layer opacity to zero, the rotation will still be visible.... then I set opacity back to 100. Sometimes I use guidelines for reference.
- Pilosopong Tasyo
Vectorator wrote:But when I am rotating is there a way to hide the un-rotated image? I can only see how to hide the rotated image.
AFAIK, the GIMP doesn't have the provision to allow you to hide the original image while you are rotating it. Otherwise, you should have already seen it in the tool options box.
I'm guessing you want to straighten the original image? What I do in this case is use corrective direction, disable the preview, enable the guides and rotate the superimposed grid lines to visually match the edges of the image below, adjusting the number of lines until I find a satisfactory match. I use this method to straighten scanned photos and documents. Works like a charm every time.
Original > Settings > Corrected
HTH.
Wrongfully banned in March 2014. All my posts prior to this date were unceremoniously removed. I was told there was supposed to be in a backup somewhere. Still waiting for my old posts to be restored (more likely it's hello bit bucket).
(ノಠ益ಠ)ノ彡┻━┻
(ノಠ益ಠ)ノ彡┻━┻
Vectorator
Ok thanks.
Yes simply hiding the layer before starting to rotate pretty much achieves what I want.
