Hi!
I use the palette at the bottom to select the fill color. Can that palette be used to select the stroke color? How?
Thank you!
Dr. T
Palette at the Bottom
Re: Palette at the Bottom
Click on a palette swatch with the shift key held down. Or you can drag the swatch to the lower box for stroke and to the upper box for fill.
Thiagarajan
Or drag the particular swatch over the object, while holding down Shift Key. The object needn't be selected.
