Hi!
When wanting to use layer modes like screen, dodge and multiply
I have a problem that transparent areas do affect bellow layer.
Like a square with no fill darkening that under,
or text having a square around it that it shouldn't.
How do I solve this?
Thanks!
Layer modes difficulties
Re: Layer modes difficulties
I can't reproduce that behavior, can you share a file?
Here is a sample.
When top layer is set to non-normal, a square outline is added.
I guess it has something to do with filters
- Layer problem.svg
- (39.3 KiB) Downloaded 227 times
It's not the filters *in* the layer, it's the blend mode itself that does this. I cannot tell if this is to be expected - but Lazur will be able to.
It can be corrected if you add a composite:in filter primitive to the filter chain. Guess it's a rendering bug.
In general.
But honestly after opening your file can't see the glitch at the moment. Testing.
Edit: attaching a test example.
blend test.svg
In general.
blend test.svg
@Lazur - there's no attachment, maybe some formatting issue?
Hmm probably there's an issue with attaching files? Saw it happen in another post recently the attachment missing.
Correcting it with a dropbox hosted file.
Thanks for checking.
Will try the composite:in filter primitive next time.
Off topic:
testing attachments
inline:
not inline:
testing attachments
inline:
not inline:
- sfav98.png (8.34 KiB) Viewed 2312 times
