I've restarted Inkscape 3 times, but this problem keeps recurring, which makes me suspicious of it potentially being a bug. I have 2 straight open paths, separated by ~1000 px, and interpolated by 300 steps (making a fabric texture). To the group of stroked paths I've applied a gradient. I added one stop, set its color and adjusted it, then I went on to other things. The next time I selected the group and switched to the gradient tool, the handle of the intermediate stop didn't show up. I''ve tried everything I can think of to try and make it show up -- selected a handle, selected both end handles, moved the handles, switch to Selection tool and back to Gradient tool -- but I can't make them show up.
I have had a problem with Inkscape, which has happened fairly often, where a button or a menu item just stops responding to the mouse. (started with 0.47) It's never happened to more than one button or menu item at a time. Often it seems to be a button or menu item that I'm using heavily in that session, but not always. Closing the file and reopening resolves the problem every time.
At first, I thought this was that problem, so I restarted Inkscape. The intermediate stop was showing up again, and so I thought, well, this is the first time it's happened to a tool or handle. But then the next time I selected that group and switched to the Gradient tool, the stop waas once again not visible. This time, in addition to selecting stops and moving handles, I tried adding more stops, in attempt to make them show up. But the newly added stops are not visible either.
Now I've gone through the same routine 3 or 4 times, and the intermediate stops keep on disappearing. So I'm thinking it's a new bug. However, I'm not sure enough, to submit a bug report. So hopefully some of you can test, and we can sort out whether this should be reported. This is on Win7, 64-bit and the new Inkscape 0.48.4.
I have not tested different kinds of objects, or on grouped vs not grouped. But I do have a simple closed path with a gradient fill, which is behaving properly. I'll try to narrow down the specifics as soon as I can. But of course, any input from others will still be helpful
Thanks for your help
