Made an SVG with a filtered effect (drop shadow).
Saved a copy as pdf (rasterize filter effects selected, 300).
PDF looked ok in Adobe Reader.
Opened pdf in Inkscape via Poppler, no filtered object?
Poppler import kills filtered item(s)?
- Third item is PDF opened in Inkscape via Poppler
- MissingFilterPdf.jpg (105.2 KiB) Viewed 2134 times
- T1.pdf
- (29.62 KiB) Downloaded 189 times
- T1.svg
- (5.37 KiB) Downloaded 244 times
Re: Poppler import kills filtered item(s)?
It works here on 0.48.
I assume it's not the filtering, but the "embedded raster image with alpha channel shades" the rasterisation produces.
Which is implemented as a raster image masked by another raster image in the pdf.
Can be a bug.
Can be a bug.
Seems anything masked does not save as pdf with .91.
- t5.svg
- (3.27 KiB) Downloaded 190 times
Same here, anything masked with other shade than white -which could be covered by clipping.
Contrary transparent raster images are saved with masking.
