the title says it all i think but just to explaine.
i want to work on several shapes on screen which involves selecting one to weld it to another shape, but i want to keep my original on screen as a guide, but when i drag a selection box around my active shape i sometimes select the original too.
is there a way i can keep the original on screen but freez it so that it wont be selected by mistake.
hope that makes sense
thanks
[solved] Is there a way to freeze an object on screen
Re: Is there a way to freeze an object on screen
You can lock an object using the Object Properties dialog (on the Object menu, or right-click on the object).
To unlock things, you can use the Unlock All option on the Object menu.
thats perfect just what i was looking for, thank you
You could also put the original on another layer (at the bottom) and then lock this layer. I think that's better sollution for refference image because you can lock/hide it easily anytime you want.
I also recommend using layers.
SureWhyNot
"weld"? You play garry's mod?
