I'm working offline. i.e using localhost harddisk, rather than remote server.
I've tried standalone SVG, as well as SVG embedded in HTML.
SVG code validates cleanly.
Firefox and Opera display only <text>
IE displays onlt top third of 'page' ! ! !
Windowd-Safari displays perfectly
This is my HTML:
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html>
<head><title>Test Scale & Translate</title></head>
<body width="700" height="600">
<!-- Belt and Braces. -->
<!-- New browsers deprecate '<embed>' -->
<!-- Old browsers know nothing of '<object>' -->
<object data="grid.svg" width="100%" height="100%" type="image/svg+xml">
<embed src="grid.svg" width="100%" height="100%" type="image/svg+xml" />
</object>
</body>
</html>
This is the heavily commented SVG:
<?xml version="1.0" encoding="utf-8"?>
<?xml-stylesheet type="text/css" href="grid.css"?>
<svg width="700" height="600" viewbox="0 0 700 600">
<!-- Draw 'pixel scale' Top-Left -->
<path d="M0,500 L0,0 L600,0" />
<!-- Draw Horizontal markers -->
<path d="M10,0 L10,50" /> <path d="M20,0 L20,50" /> <path d="M30,0 L30,50" /> <path d="M40,0 L40,50" /> <path d="M50,0 L 50,50" />
<path d="M60,0 L60,5" /> <path d="M70,0 L70,5" /> <path d="M80,0 L80,5" /> <path d="M90,0 L90,5" /> <path d="M100,0 L100,10" />
<path d="M110,0 L110,5" /> <path d="M120,0 L120,5" /> <path d="M130,0 L130,5" /> <path d="M140,0 L140,5" /> <path d="M150,0 L150,10" />
<path d="M160,0 L160,5" /> <path d="M170,0 L170,5" /> <path d="M180,0 L180,5" /> <path d="M190,0 L190,5" /> <path d="M200,0 L200,10" />
<path d="M210,0 L210,5" /> <path d="M220,0 L220,5" /> <path d="M230,0 L230,5" /> <path d="M240,0 L240,5" /> <path d="M250,0 L250,10" />
<path d="M260,0 L260,5" /> <path d="M270,0 L270,5" /> <path d="M280,0 L280,5" /> <path d="M290,0 L290,5" /> <path d="M300,0 L300,10" />
<path d="M310,0 L310,5" /> <path d="M320,0 L320,5" /> <path d="M330,0 L330,5" /> <path d="M340,0 L340,5" /> <path d="M350,0 L350,10" />
<path d="M360,0 L360,5" /> <path d="M370,0 L370,5" /> <path d="M380,0 L380,5" /> <path d="M390,0 L390,5" /> <path d="M400,0 L400,10" />
<path d="M410,0 L410,5" /> <path d="M420,0 L420,5" /> <path d="M430,0 L430,5" /> <path d="M440,0 L440,5" /> <path d="M450,0 L450,10" />
<path d="M460,0 L460,5" /> <path d="M470,0 L470,5" /> <path d="M480,0 L480,5" /> <path d="M490,0 L490,5" /> <path d="M500,0 L500,10" />
<path d="M510,0 L510,5" /> <path d="M520,0 L520,5" /> <path d="M530,0 L530,5" /> <path d="M540,0 L540,5" /> <path d="M550,0 L550,10" />
<path d="M560,0 L560,5" /> <path d="M570,0 L570,5" /> <path d="M580,0 L580,5" /> <path d="M590,0 L590,5" /> <path d="M600,0 L600,10" />
<!-- Draw Vertical markers -->
<path d="M0,10 L50,10" /> <path d="M0,20 L50,20" /> <path d="M0,30 L50,30" /> <path d="M0,40 L50,40" /> <path d="M0,50 L50,50" />
<path d="M0,60 L5,60" /> <path d="M0,70 L5,70" /> <path d="M0,80 L5,80" /> <path d="M0,90 L5,90" /> <path d="M0,100 L10,100" />
<path d="M0,110 L5,110" /> <path d="M0,120 L5,120" /> <path d="M0,130 L5,130" /> <path d="M0,140 L5,140" /> <path d="M0,150 L10,150" />
<path d="M0,160 L5,160" /> <path d="M0,170 L5,170" /> <path d="M0,180 L5,180" /> <path d="M0,190 L5,190" /> <path d="M0,200 L10,200" />
<path d="M0,210 L5,210" /> <path d="M0,220 L5,220" /> <path d="M0,230 L5,230" /> <path d="M0,240 L5,240" /> <path d="M0,250 L10,250" />
<path d="M0,260 L5,260" /> <path d="M0,270 L5,270" /> <path d="M0,280 L5,280" /> <path d="M0,290 L5,290" /> <path d="M0,300 L10,300" />
<path d="M0,310 L5,310" /> <path d="M0,320 L5,320" /> <path d="M0,330 L5,330" /> <path d="M0,340 L5,340" /> <path d="M0,350 L10,350" />
<path d="M0,360 L5,360" /> <path d="M0,370 L5,370" /> <path d="M0,380 L5,380" /> <path d="M0,390 L5,390" /> <path d="M0,400 L10,400" />
<path d="M0,410 L5,410" /> <path d="M0,420 L5,420" /> <path d="M0,430 L5,430" /> <path d="M0,440 L5,440" /> <path d="M0,450 L10,450" />
<path d="M0,460 L5,460" /> <path d="M0,470 L5,470" /> <path d="M0,480 L5,480" /> <path d="M0,490 L5,490" /> <path d="M0,500 L10,500" />
<!-- Label Horizontal 100 200 300 400 500 -->
<text x="90" y="25" >100px</text> <text x="190" y="25" >200px</text> <text x="290" y="25" >300px</text>
<text x="390" y="25" >400px</text> <text x="490" y="25" >500px</text> <text x="590" y="25" >600px</text>
<!-- Label Vertical 100 200 300 400 500 -->
<text x="15" y="105">100px</text> <text x="15" y="205">200px</text> <text x="15" y="305">300px</text>
<text x="15" y="405">400px</text> <text x="15" y="505">500px</text>
<!-- Add explanatory Text -->
<text x="100" y="60" >GRID defined as:</text>
<text x="195" y="60" >Positioned at 50,50</text> <text x="300" y="60" >Size: 50x50</text>
<text x="100" y="75" >The Grid can be re-positioned and / or re-sized.</text>
<text x="330" y="75" >( Curently: </text> <text x="388" y="75" >Translate ( 50, 0 )</text>
<text x="480" y="75" >Scale ( 5, 5 ) )</text>
<text x="100" y="90" >The values may be changed , or the order of commands may be changed.</text>
<text x="100" y="105" >Order of commands is significant, as the Second is dependent on the First.</text>
<text x="100" y="120" >( Note how both the Stroke-width and the Text-size are affected by the scale.)</text>
<text x="100" y="150" >Top-Left and Bottom-Right corners are labelled with the original defined positions, (50,50 and 100,100),</text>
<text x="100" y="165" >Repositioning and Scaling has effectively changed them. They now appear to be 300,250 and 550,500.</text>
<text x="100" y="180" >( Note: The Grid was originally the size of the 50x50 grid in top-left corner.)</text>
<!-- To change the Position and the Size of the Grid -->
<!-- adjust the values in the two 'transform' commands below, -->
<!-- and amend the corresponding values in the descriptive 'text' lines above (y="75"). -->
<!-- N.B. These 'transforms' are 'nested'. Changing their order, changes their effect. -->
<!-- define Transforms -->
<g transform="translate(50,0)" > <!-- To define the X,Y start position. (0,0)='no change' -->
<g transform="scale(5,5)" > <!-- To change the X and Y scales. (1,1)='no change' -->
<!-- Draw Grid -->
<g> <!-- Draw the 50x50 Grid -->
<text x="35" y="47" >50,50</text> <!-- Label Top-Left corner -->
<path d="M 50,50 L 100,50" /> <path d="M 50,60 L 100,60" /> <path d="M 50,70 L 100,70" />
<path d="M 50,80 L 100,80" /> <path d="M 50,90 L 100,90" /> <path d="M 50,100 L 100,100" />
<path d="M 50,50 L 50,100" /> <path d="M 60,50 L 60,100" /> <path d="M 70,50 L 70,100" />
<path d="M 80,50 L 80,100" /> <path d="M 90,50 L 90,100" /> <path d="M 100,50 L 100,100" />
<text x="80" y="110" >100,100</text> <!-- Label Bottom-Right corner -->
</g>
</g>
</g>
</svg>
Can anyone give me advice,
Please, and Thanks,
JJ
