Hi
Did a graphic for Woo-commerce Slider Revolution, but it hasn't saved properly. The top edge is showing some transparency, but there wasn't any transparency in the blue base.
I tried going back to rectify the thing but it just keeps coming back as is. Please see attachment.
Thanks.
Top of graphic showing transparent
- Flash.png (96.43 KiB) Viewed 756 times
Michael
(centurian)
(centurian)
Re: Top of graphic showing transparent
Maybe you need to resize the page to the contents? (File -> Document properties, first tab, directly below the width / height values).
Or you can just export the blue rectangle (select, go to File -> Export PNG image).
If this doesn't work, it would help us to have the original SVG image to look into.
