Using the Inkscape verb "AlignVerticalCenter" I'm able to easily align an object through the CLI. When I do this, the object is vertically centered to the page.
Within the Inkscape GUI Align and Distribute interface, there is a dropdown titled "Relative to".
I would like to be able to "AlignVerticalCenter" relative to the drop-down menu value "selection area". Unfortunately, there does not seem to be a verb to set this "Relative to" value.
Anybody know of a workaround?
Any help is much appreciated.
Regards,
Wyatt
How to AlignVerticalCenter to selection area?
Re: How to AlignVerticalCenter to selection area?
Selection area is not a preserved dimension in vector drawing programs the menu item is deceptive. it used to just say "selection" which means the bounding box of all selected items no matter how big a selection marquee was used, and it still works that way even though the word 'area' has been added. not sure if a verb exists for the old one but if it does it would probably be the same Does that help or maybe you knew that already?
I use it to vertically center text within a rectangle.
I select a rectangle, I select text. I choose "selection area", then press the align vertical center button and the text centers inside my box.
Is there a different way to vertically center text within a box automatically?
I thought it used the setting that was last set in the dialog for the command line functionality. So that isn't the case?
I can test this, but manually setting it in the GUI dialog doesn't really help my case, as I have some code actions that align by page, and require other code actions that need to be aligned by "selection area" within the same command line.
Ah, okay. These commands (--verb) don't take any parameters currently.
If you're fluent in python, you could write an extension that makes use of Inkscape's simpletransform.py file, and can read data from a file... :-/
