Why does a square show up in the SVG file as:
width="1023.46051"
height="1023.46051"
x="0.2697373629"
y="28.63189507"
Yet, the canvas size is 1024x1024, and the viewbox is 0 0 1024 1024, and document settings are in px.
I understand that the 28.6 is due to a transform, but the rest doesn't make sense.
Is this some sort of rounding error? I have the numeric precision set to 10 (min exp -10). Any way to fix this? It needs to be accurate because I use an XAML export (same problem) for a game.
Rounding error?
Re: Rounding error?
do you have a stroke set on the object?
Check the attached file, and feel free to share yours.
- 1024x1024.svg
- (1.78 KiB) Downloaded 253 times
Re: Rounding error?
You are right, the stroke was the issue. Thanks so much!
I still wonder why it adds a transform though. Usually 0,-28.36
Any way to disable that or work around it?
Re: Rounding error?
elecman wrote:I still wonder why it adds a transform though. Usually 0,-28.36
I'd ensure the transforms in the preferences> behaviors are set to store as optimized.
If this will be used frequently, I'd also setup a custom template that can be used for each new document (Menu: File>Templates):
- delete layers
set default units to px
set page to 1024x1024
include the rectangle object if it also will be used frequently and position to 0,0
