Hi guys,
I have created a graphic in inkscape for mac by drawing paths and filling them. All is great when the graphic is over 100px large. But when I reduce below this size 2 areas of my graphic lose the fill. I have double checked the boxes and everything seems equal on each box. Any ideas?
Attached is the graphic for you to see.
Thanks in advance
When image is small fills disappear
inkscapeuk
- finalbutterflyMPfinal2.svg
- (33.26 KiB) Downloaded 293 times
inkscapeuk
Re: When image is small fills disappear
So when the image is 84px or smaller it looks like this, when it's 85px and larger it looks like this
- image84px.pdf
- (8.71 KiB) Downloaded 269 times
- image83px.pdf
- (7.24 KiB) Downloaded 272 times
If the design is that small it may be a better idea using a raster copy of the object instead.
Even that the original design is semi-transparent, uses alot clipping, fills AND strokes too of 0,05 px width, the rendering of it would be much reliable.
