This is the image"
What I want to do is to delete the path inside the orb, so that it appears the ring goes around the orb. It seems like this should be easy to do, but damned if I have been able to do it, even after looking at threads about nodes and using the inkscape guide all morning. Any help would be greatly appreciated, sorry for asking such a simple question, but everyone is a novice at some time, no?
Jaime
) select each node (which define the segment you want to delete) and click the "Break path at selected nodes" button. Then, just select the segment, and click delete, or use the keyboard Delete key.
