Symtom:
(Inkscape21165-0904171530.7z)
Inkscape can not open files containing linkedoffset with inkscape:radius. After click open the file, the process uses up CPU time and stays not responding.
I have to move back to 0.46 which is much slower than nightly build.
Questions:
1. Is there anybody experience this?
2. Is this a bug?
3. Is there any workaround?
Thanks.
win32 nightly build can not open linkedoffset with radius
- test.svg
- Text with a Linked Offset
- (7.12 KiB) Downloaded 254 times
- EarlyBlake
Re: win32 nightly build can not open linkedoffset with radius
Did you try an earlier build?
EarlyBlake wrote:Did you try an earlier build?
The earliest build in the download page (Inkscape21024-0904010548.7z) doesn't open the linked offset either. I have no archive builds earlier than in the download page.
EarlyBlake, do you have symtoms like me? (try open my attachment--test.svg above with your build)
- EarlyBlake
Sandthorn wrote:EarlyBlake wrote:Did you try an earlier build?
I've got the march 12 th build and it wont open.
Sounds like it might be worth you logging a bug report for this on Launchpad. Or letting the developers know on the mailing list.
EarlyBlake wrote:I've got the march 12 th build and it wont open.
microUgly wrote:Sounds like it might be worth you logging a bug report for this on Launchpad. Or letting the developers know on the mailing list.
I have posted this to the launchpad.
https://bugs.launchpad.net/inkscape/+bug/365034
Thanks EarlyBlake and microUgly. Hope this will be fixed soon.
I've just found that if a linked offset with radius attached on something other than "text object," it's fine.
I tried this
1) Create a text object.
2) Convert to path.
3) Ungroup it.
4) Combine it into a single path.
5) Create Link Offset with radius 15.
6) Reopen file. It works.
So I tried this,
2) Create Link Offset with radius 0
3) Reopen. It works.
4) Create Link Offset with radius 15 on previous Link Offset
5) Reopen. It crashes.
I guess the problem occurs
"only when a linked offset with radius is able to be traced back to a text object."
Regards,
Sandthorn
I tried this
2) Convert to path.
3) Ungroup it.
So I tried this,
Regards,
Sandthorn
- When Converted to Path.svg
- It works when converted to path.
- (28.1 KiB) Downloaded 303 times
This bug is now reported fixed in in rev. #21263.
https://bugs.launchpad.net/inkscape/+bu ... comments/5
