I was trying to write my own extension, and I was wondering if it was at all possible to access shortcuts within the script. Specifically, Is there any way an inkscape extension can automatically select all objects in a given svg image? I know I can do it with ctrl+a but I was hoping there was a way of doing it automatically.
Thanks in advance,
Nathan
Shortcuts in inkscape extensions
Re: Shortcuts in inkscape extensions
My very limited understanding of Inkscape extensions - based on creating just one - is that they are external programs that are passed a complete copy of the XML, plus a collection of selected objects. They return a modified copy of the XML. There's no way that I could find to also return a selection, or to trigger any keyboard shortcuts within Inkscape itself.
Essentially an extension is a black box with XML fed in at one end, and XML coming out at the other end. There's not really any interaction with Inkscape itself, other than as a source and sink for the XML.
Xav wrote:My very limited understanding of Inkscape extensions - based on creating just one - is that they are external programs that are passed a complete copy of the XML, plus a collection of selected objects. They return a modified copy of the XML. There's no way that I could find to also return a selection, or to trigger any keyboard shortcuts within Inkscape itself.
Xav, you are right... but in theory it's possible to have some access to some features of Inkscape using the command line"verbs" system
http://tavmjong.free.fr/INKSCAPE/MANUAL ... Query.html
Some extensions implement this feature (the export to synfig extension, if I'm not wrong)... but you have to code it. A better approach would if were just a module...I guess...
From time to time, this same topic is discussed here in the forum.
If you have problems:
2.- Please check here:
I don't get it.
As Xav said the extension is called with the path of an xml file (and a list of selected items) and wrote a [modified] xml.
I don't see when you could pass a query to [the already running instance of] inkscape.
Unless your extension calls another [hidden] instance of inkscape which would be quite complicated imho
I'd be glad to hear more about interacting with inkscape from an extension.
v1nce wrote:I don't get it.
That is the idea... I think
See this link... the comments at the end also have information
http://www.janthor.com/sketches/index.p ... scape.html
Greetings
Nathan1123
Looks really promising! However, when I call the --query-all command, the resulting coordinates are very different from the actual object locations. Why are they different? and is there some way I can compensate for that?
For example, one of the entries in --query-all comes out as:
text399, 30762.015, 12013.469
However, the actual coordinates of text399 is 30949.857, 12123.882
Nathan1123
Well, it's working now. Guess the translated locations are proportionally the same.
Thanks so much!
Thanks so much!
